Samsung PN58C8000 TV Logo
Anonymous Posted on Jan 27, 2011
Pn58c8000 stuck in DEMO mode after update. the plug & play settings are grayed out so i cant access it. also the "tools" doesnt work either (there's a demo option). help..
Anonymous
Level 3:
President:
  • Master 2,080 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
President:
Answers
2080
Questions
Helped
927879
Points
6465
Try holding down the DISPLAY or the MENU button on the front of the set for 10 seconds, sometimes that works.
  • Anonymous Jan 27, 2011
    hi. there is no display button on remote or pannel. the Menu button held down for 10 sec opens the menu then tells me the tv is in DEMO. lol. im going try to manually update the firmware to the same current one that installed. I heard the tv resets after a manual firmware update. any other suggestions please continue.
    I'm assuming you have a copy of the USER"S MANUAL.
    I'm looking at the QUICK START GUIDE found at the following link:
    http://downloadcenter.samsung.com/conten...[PC8000-QSG]BN68-02619A-03Eng-0903.pdf
    Maybe try unplugging the power cord and leaving it out overnight. This might reset the internal memory to default settings and let you access the PLUG AND PLAY menu once you turn it on again.
Can't get out of demo mode to set time
Press clock timer set.
Turn selector to set the hour.
Press enter. Minutes will flash.
Turn selector to set minutes.
Press enter.
Setting the clock will deactivate demo mode.
tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
2answers
When I plug in power cord, unit says "Hello", cycles through all settings, says"goodbye, then starts all over again. I can play a CD all the way through.
Sounds like its stuck in demo mode. Look up model number on the internet if you don't have a manual. Hope this helps
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
2helpful
How do i get archos 101 out of demo mode
This is directly from Archos' support website:
http://www.archos.com/support/support_tech/faqs/en/faq_Archos5.html?country=us&lang=en
You cannot exit the demo mode without the code you created.
Contact Archos Technical Support via the help form on the website and give your 'Product key' (Tools > Settings > Firmware and Plug-ins).
The demo mode included in the device is designed to be used at retailers ONLY. Do not use it as it merely searches for two short video demonstrations to play in a loop for store displays.
Accidently entered into store mode, but cant enter "plug and play"
hi, let try this.
Open menu , choose setup - push enter.
Choose plug and play, enter language , pass code, than follow instruction until setup home use and demo store appear.
Choose home use.
Its work with my TV.
2helpful
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
    Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
  1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
49helpful
5answers
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
10helpful
How do I turn off Demo mode on Archos 5
Click Tools -> Settings -> Firmware and Plug-Ins and click stop demo Firmware (Mine is not activated and this may not be there).
1helpful
2answers
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
