SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
SOURCE: low toner & paper jam
There is a problem with the HP 2015 printer. The symptoms you describe are a common fault requiring the printer to be returned to the HP repair centre.
Out of a batch of 40 2015 printers, we have had to return 9 so far for the same problem. 2 of the 9 have been back twice... The printers come back with new MAC addresses and this suggests that the main motherboard is being changed.
SOURCE: Paper jam message
check the paper tray to make sure paper goes up. Also check to see if there are any obstructions in the paper path.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
