My son has a DS Lite which has stopped recharging, when the charger is plugged in it shows the red lite for a second thenit goes off, have tried a different charger, battery and plug but nothing works.
My son has a Nintendo DS Lite and it will not charge. When plugged in it doesn't even indicate that is is accepting the electricity to charge.My son has a Nintendo DS Lite and it will not charge. When plugged in it doesn't even indicate that is is accepting the electricity to charge.
The DS's battery has a limit to how many times you charge it,but then again the charger's wire inside it might be disconnected.
Try to buy a new DS charger and see if its the wire,if its not then try to call nintendo to see if they might be able to replace the battery(for a fee).
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
I have the same problem, the power cannot stay on what can we do?
No I have tried a new battery and it wont turn on
Does it play when you put a charged battery in it?
You may have a broken electrical connection from the charge jack.
