A pipe can be seen as two cylinders, one of "air" sitting inside the other, in this case lead.
To get the volume of a pipe you thus subtract the volume of the "air" cylinder from that of the lead cylinder.
Volume of a cylinder = area of circular cross section (or pi times square of the radius) times the height (or length) => ? * r2 * h
Volume of a pipe = Volume of cylinder 1 (outer diameter) - volume of cylinder 2 (inner diameter).
In this case; Volume of outer cylinder => inner diameter 1/2" (0.5") + pipe thickness 1/4" (0.25") = 3/4" (0.75") divided by 2 to get radius = 0.375".
3.14 (?) * 0.375 * 0.375 * 120(10 feet) = 53.01438 in3
Volume of inner cylinder => inner diameter 1/2" (0.5") divided by 2 to get radius = 0.25".
3.14 (?) * 0.25 * 0.25 * 120(10 feet) = 23.56194 in3
Volume of lead in this pipe = 53.01438 - 23.56194 = 29.45244 in3
Hope this helps ;)
Seems like the FixYa system doesn't accept some "special characters" the question marks you see in my answer should be the sign for Pi ~ 3.141596...
OOPS! I made a mistake ;) Outer cylinder volume should be: inner diameter 1/2" (0.5") pipe thickness 1/4" (0.25") *2 = 1" divided by 2 to get radius = 0.5". = 94.24778 in3
The correct volume of lead in this pipe is = 94.24778 - 23.56194 = 70.68584 in3
In case you would like the formula for the volume of a pipe: volume = Pi * h * (ro2 - ri2)
ro2= outer radius squared, ri2 = inner radius squared.
Sorry (blush)
