If the phone you are trying to Restore is Nokia just follow this ,first type *#7780# or select "Restore Factory Setting".and enter security code 12345 or what you have made.If you select "Restore All" all your data which is stored in your phone memory will automatically erase.Thanks for visiting fixya
This option restores the .ini files from the ROM. Does not erase data (photos, videos, documents) or applications from a third party. Key Code *# 7780 # (click this combination of keys on the keyboard in the mobile) 2.- Total Reset or Hard Reset
This option restores the original operating system from the ROM. Formats the C: partition and deletes all data including the memory card. Key Code *#7370# (click this combination of keys on the keyboard in the mobile)
Reset you phone settings with the Sim Card to Full Factory Restore using 12345 or *#7370# or *#7780#. Remember the later two will reset all the your settings as well as your phone memory. Good luck..
Do you have a white, blue screen or no display at all?
If you are able to turn on your phone but it remains blank, you can format it. How ever this will erase all your phone memory data as your phone is restored to factory settings. Your memory card and SIM card data will not be affected how ever. To format your phone, use the following steps.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
1. Make sure you have at least 3/4 charge of battery power
left.
2. Switch-off your phone.
3. Press and hold these 3 keys; Green dial key, * (star key)
and no. 3 key and then press the power on/off to switch on the phone.
Remember, do not let go all of the keys, hold until you see
a formatting word screen show!
4. After a few minutes when the full phone formatting
completed, your phone will be back to original system and factory settings.
i think your phone memory is full or your symbian operating system may have some fault it can be fixd easily format the phone is the only solution follow this step just format the phone by swtiching off the phone first wait 30 seconds now hold the three buttons toghther that is calling key ,numeric pad no. 3 key and * key and swtich on the phone wait for it to show formatting and you can unlock your phone easily but your data in the phone memory will get erased but the sim memory and memory card will not erased
if u hav forgot your passs word then restart your mobile and then connect to pc suit and crack your password or you can format your mobile ,your all phone memory data will lost bur your pasword will become as by given mobile set
Try *#7370#. Before using the above code make sure you backup all your phone memory data like contacts, messages, documents etc because this process erases all the data by formatting your phone & restoring it to original factory settings.
Just Reset Your Mobile Phone Settings RESTORE FACTORY SETTINGS Automatically Remove all errors from your mobile phones Before resetting Backup your Contacts Massages and All Gallery
