Laptop
heatup is mainly due the clogged heat sink and fan etc, which requires
to be cleaned. Laptop shuts dwon automatically when reaches the temperature limit to prevent damage. It is strongly recommended that you clean the heat sink
etc yourself or seek help from authorized professional at the earliest to
avoid any damages to the PC.
If you are familiar with working inside such electronics, then you can do it yourself after studying the following useful links about CQ-50 Disassembly. On the contrary, if you dont have sufficient experience/ idea about opening/ repairing laptops, DONT try it and get assistance from a professional,
Dissassembly CQ-50
Maintenance & Service Guide CQ-50
Hope it helps! Do convey your feedback
CreativeTECH
this is actually a design flaw problem for the cq line, the case has vents underneath but none on sides, even rear vents point downwards. hot air cant escape properly, even on a table surface.
I blew out fan and it worked for 2 weeks then it started shutting off again. I found lint in fan after using your diagram so just blowing it out isn't a good idea. I still have shuts offs to the point I can't even run diagnostics. I noticed the copper has a little redness where it meets processor is this part burnt now what else can I do?
I found out I must clean and replace the heatsink thermal compound between heatsink and CPU.
Get a new computer
Processor fan not running or dirt in or on heatsink around processor
SOURCE: shuts down in middle of session; overheating??
no...u have a problem in hardware and is not working as good so try this 1st trouble(1) remove the memory then make a clean(2) remove the mini HDDrive then put it back again(3) if their a same again a problems,last step (4) you need to make a re-programs or re-install the Windows/OS...Good Luck and Have a nice Day..^_^
