Ricoh Aficio 450 Copier Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Add toner - Ricoh Aficio 450 Copier
Anonymous
Level 2:
Sniper:
  • Expert 59 Answers
  • Posted on Jan 27, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
59
Questions
0
Helped
65740
Points
127
If machine sade add toner it's mean toner finished in the machine and add the new toner bottle if problem exist than clean the toner hopper
I'm using Taskalfa Kyocera 250ci, there are enough toners inside the catridge. And, it's still complaining about toner saying add toner. What can be the cause of it?
1 or more of the developers is leaking. because the machine adds toner based on a ratio of developer to toner when the developer level is not right machine tries to compensate by adding toner it will always say add toner until the developer unit is changed
1helpful
3answers
How to solve add toner see instruction front cover to replace toner ricoh mp2000
If you just add toner and it just keep saying add toner. open sp mode.
Press: Clear modes>1-0-7>Clear/Stop> SP2 x x x- Drum > 214 -Developer Initialization>Exectute and wait.
please rate. thanks
2answers
Toner dumping straight into toner bag
use original toner OR reset toner indication
2helpful
2answers
I fix new drum,developerand toner but still showing add toner
after you do all those things you will have to add toner. If you did all that because it was asking for toner you wasted all of that work (and parts) by not adding toner.
7helpful
4answers
Message says to add toner after I replace toner
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
1helpful
How to add toner
Open the front cover. Towards the right side about half way down, there is a plastic lever. This will rotate to release the Developer/Toner Unit away from the Drum Unit. Pull the Unit outwards...it should stop before coming all the way out (unless someone has removed the stopper) Please use the correct type of Canon Toner as it fits on top of the Unit and unlatches Toner cover to add the toner. (Canon Type GPR-2). The instructions should be in picture format on inside of front cover.
2answers
Add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
3answers
Add toner message
have you tried another toner cartridge? eyo7 [email protected]
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
