Question about Casio G-Shock Classic DW6900-1V Wrist Watch
How do I change 24 hour time to 12 hour - Casio G-Shock Classic DW6900-1V Wrist Watch
    New Friend:
  • 3 Answers
You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
Posted on Jan 02, 2013
1-go to this link http://world.casio.com/wat/download/en/manual/
2-follow the instructions
3-get detailed user's manual for your G-Shock
Posted on Jan 27, 2011
SOURCE:
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: cannot change from 24 hour to 12 hour
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Posted on Mar 14, 2010
  • 2501 Answers
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Posted on Feb 03, 2010
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
escapement
  • 2338 Answers
SOURCE: how change from 24 hour to 12 hour AM/PM mode on
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.
Posted on Mar 18, 2010
Change time indicator from military time to 12 hour time.
Google is your friend in such cases
Google
make model manual
Here are a few to be going on with
How do change time from 24 hour to 12 hour settings Google Search
Jun 13, 2018 | Military Time Watches
Skemi watch 1068 changing the time from 24 hour time to 12 hour time
On a different Skmei model, you can toggle the 12/24 settings within alarm settings. This also changes the setting for displayed time.
As I suspect that a lot of their models use the same internal module, it's worth a try.
Sep 29, 2017 | The Watches
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Mar 12, 2014 | Maxi Aids Shake n Wake ZZZ Vibrating Alarm...
Xinjia xj-686 change to 24 hour mode
Change time. It will alternate between 12 hours and 24 hours.
Apr 02, 2012 | Watches
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Mar 10, 2008 | Timex 27191 Wristwatch
24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Jul 05, 2007 | Timex Fashion Classics 78587 Wrist Watch
Casio G-Shock Classic DW6900-1V Wrist Watch Logo
5,812 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
