Cab Dryer Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I had the same problem with mine and is only four months old.Un-plug the dryer, pull the rotating knob from the control panel, then remove the control panel by removing two screws in the back, after pulling the control panel you will find a tech sheet, with the help of this sheet locate the thermal fuse, remove the one screw holding it to the dryer and remove the two cables from the fuse. You can buy a generic fuse for about $5. or the original for $15. I bought mine at AP WAGNER, they have everything. Good luck.
