Lucent PARTNER18 Corded Phone Logo
Posted on Jul 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change te number of rings
How can i set it ?
Anonymous
Level 2:
Champion:
  • Expert 211 Answers
  • Posted on Mar 21, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
211
Questions
0
Helped
75146
Points
371
On extension 10 or 11 press Feature 00, left intercom twice, #506, mode 1, line 01, x (number of rings from 1 to 6)
Do the same for all lines.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
599
Points
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
I have set the ring tone and now want to cnange it keeps going back to the same one
Check te location from where you are changing the ring tone.
Jun 25, 2018 • Cell Phones
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
How do i take off a change amount that seems to have beeen programmed into my casio te4000f everytime i ring up a sale...
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG
If anyone needs more information, the Casio TE-3000s, TE-4000F and TE-4500F manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
How do you program HST on my TE4500?
Which tax number has been set for HST? you have to set the rate on the correct tax number.
If anyone needs / looking for a Casio TE-3000, TE-4000F, TE-4500 manual, c-tech collective have them here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
2helpful
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
3helpful
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
2helpful
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
3helpful
To change # of rings you have to go into programing OK press feature * * on the main set and config (266344) then the password admin (23646) this goes to terminals and sets hit show and enter the set you want to change go to capabilities this will allow you to chang # of rings on that set
2helpful
How can I change the Rings to Answer setting to one ring?
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Top Lucent Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
