If you put the door lamp back and the tv keeps resetting you have problem with the power unit too
Okay you have to make sure you close the door that the buld goes into there is a liitle micro switch that only triggers when the cover is removed it stops the tv from lighting up the bulb once you close the door and all are put back together properly the tv will come on if it dosent you need to read in between the flashing codes
