SOURCE: how do i use the square root on my ti 36x
There is a dedicated key for the function. The key is labeled as on the third line of the table below. You enter a positive number, press the key and then hit [=]. Hope it helps.
SOURCE: Texas instruments - Orion ti-36x manual
Try http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
SOURCE: please explain which buttons to push on TI-36x
You need the [EE] key to enter powers of 10 exponents.
You need the change sign key [+/-] key.
You need the [LOG] key.
pKa: 6.5 [EE] [+/-] 5 [LOG] [+/-]
There are two change sign: The first (either before or after the exponent 5), the last is entered after you press the log key , so as to negate (make negative if result is positive, and make positive is result is negative) the value.
The result should be 4.1870866 or 4.19
SOURCE: Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
