SOURCE: Please show me step by step on using the Lexar 2GB
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: Hi there, I'm having problems opening the files
If you have files on the stick and it asks for formatting, the file system is probably damaged. Try a quick format on the USB-stick. DO NOT save any files to the stick. Use a file recover tool on it, like example: Piriform's Recuva. Use the Deep Scan function.
SOURCE: lexar jumpdrive firefly 16GB I've deleted
First of all try a data recovery program such as Wondershare Data Recovery to get the deleted files back. Get the program here,
Data Recovery Windows (for Windows OS)
Data Recovery Mac (for Apple Mac OS)
Then format the pen drive from Disk Management if you are running Windows.
Remember - Do NOT try & write anything back to your pen drive until you can recover your data safely!
