if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
In the System Properties , go to the Advanced tab and click Error Reporting.
Select disable error reporting This will make any crashing program’s window simply close itself.
You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry .
uninstall all symantic software on your computer. install avast free home edition, or AVG Free anti virus. Norton anti virus software is the worst thing you can have on your computer!
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
try to fix it by using startup disk 98,and run fdisk,dellete the partition,and create a new parition,from there you will know if your hardisk has a problem.
