SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: replace glass on front of oven
Hi You need a high temperature silicone adhesive designed for this purpose. There are a number of companies that make a suitable glue. There is also a company, http://ovendoorglue.co.uk that make a small kit specifically for the purpose of fixing your oven door. Do not use normal adhesive, as the correct adhesive not only is heat proof to 300 degrees centigrade, but also remains flexible when cured. This ensures that as the oven heats up, and the metal and glass expand, the flexibility in the glue prevents stress in the glass. Dow Corning make a glue that can be used, but be aware that it is red, and so may show. Other glues are black. Indeed the black glues tend to be slightly thicker on application and dry quicker.
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
