Hello, I have an electric dryer whirlpool YWED5300VW0 I bought it from canada with 4-wire receptacle (14-30R) and I shipped it to europe where power is 220V. I took a 3-wire cord from the electric pannel to the receptacle as follows : black (hot) to the left, red (neutral) to the right, and I connected the ground to neutral (white) in the receptacle (top and bottom). I tried to put it ON, it turn few seconds, I opened the door to check, the bulb inside burnt.
Did I make a mistake in the connection?
the voltage is approximately the same,the difference is the frequency of incoming power as power delivered in the USA is at 60 Hz. and power in Europe is at 50Hz. so some electronic parts will not operate on this frequency,you might be able to purchase a power/frequency inverter unit but not sure on this,talk to your power provider as they may have the answer to this
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
For to use it with a 220/ 240vac system,you will need to convert 110vac 60hz/to240vac 50 hertz single phase therfore your transformer should have this rating,also it has to be able to handle up to 3kw or 3000watts in power, maybe just as cheap buying a new drier....
Is there power at the dryer receptacle? Is the dryer wired directly or does wire from electrical breaker go to a receptacle first? Have it checked with a meter. If unit is wired directly have it changed to a receptacle and cord. Make sure there is power at the connections on the dryer. If everything is okay, then it is a dryer problem
Turn off breaker, Check and tighten lugs that feed dryer circuit at the breaker and at the receptacle, If that doesn't fix your problem you ll have to trace the wiring from breaker to dryer for broken wires.
Hi, you might be able to find an 8 foot dryer power cord at your local building supply or hardware, or electrical supply store. It will be labelled for a dryer. First look at the dryer receptacle. The cords come in two types, 3 or 4 wire, so get the one that will match youyt receptacle. The wirte should be # 10 minimum.
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Regards,
Rick
