Question about Planar PR3010 DLP Projector
I have a Planar PR3010 DLP projector. The problem I have is that the picture that is projected will sometimes shimmer. The white and the yellow are very distorted. They seem to be very bright. I turn off the projector and then turn it on after doing that for 3 or 4 times the picture often times comes up normal. This does not happen all the time. Sometimes it "works itself out" and sometimes after two hours it is the same. Any suggestions?
2 Suggested Answers
SOURCE:
  • 144 Answers
SOURCE: Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
Posted on May 08, 2010
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
The background projects as yellow instead of white. Everything has a yellow tinge to it.
It sounds like one of the polarisers has failed, on experience they cost £300 each to replace, and there are 3 of them. I recently bought an NEC NP115 for just over £200, very good spec for the cost. It maybe worth investing in a new one.
Hope I was helpful for you.
Aug 08, 2011 | Optoma EP771 DLP Projector
I have black spot on my screem how can i take it out thanks
you may need to clean it with a soft cloth that should help it may be dust
Jun 04, 2011 | Planar PR3010 DLP Projector
Projector shuts off
May 05, 2010 | Planar PR3010 DLP Projector
Dlp projection, keeps switching to standby, also sometimes will start up and the picture goes blank but the sound remains
The lamp may be out. Projectors need high voltage/wattage lamps. They tend to only last 2000 hours or so, which is about a year or two with normal use.
Feb 04, 2010 | LG DLP Projector 1400Lum RD-JT30...
How to replace the lamp in it
buy a new 1,then look in the menu for it.
Nov 16, 2009 | Planar PR3010 DLP Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
White outlines in HD mode
is the screen control turned up to high if so you would see white lines on a dark picture
Oct 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Planar PR3010 DLP Projector Logo
66 people viewed this question
Top Planar Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Planar Office Equipment and Supply Expert? Answer questions, earn points and help others
