Nokia 6101 Cellular Phone Logo
Posted on Jul 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Message writing When I go into the calendar and want to leave a description for aq meeting or appointment I cannot....The letters will not come out as I have punched them in they make whatever word they want to and it is frustrating.....If I want to indicate what the meeting is about or who I want to make a call to I cannot....(IE Dr Lou)....makes me want to go back to my previous phone who's battery has since died...............I find NO directives in the manual
DASEP
Level 2:
  • Expert 96 Answers
  • Posted on Jul 18, 2008
DASEP
Expert
Level 2:
Answers
96
Questions
0
Helped
20052
Points
198
When you punch in the letter on top screen there is an option of how you want the letters to come up. the 2 top green bottoms will help you to choose.
It says somwthing like alpha, multi-tap, numbers. If you choose numbers and press # 2 will come up.
If you choose multi tap and press # 2 once letter A will come up, if you press 2 two times letter B will come up and so on. Once the desired letter comes up wait till the cursors stop blinking and it will move so you can time the next letter or you can move the arrow to the right for you to type the next letter.
If you choose Alpha (or the other choice left) and you press # 2 and all the crazy letters will come up, I undeerstand, if you see letter ok for A it will stay and you can go to the next letter, for the next letter you press # 3 you get letter Bor crazy letters for that key, you move the arrow cursor down and it will show you all the letters you have in that key, you can scroll dow and the press ok on the letter that you need. What happens is that the phone has many words for each letter you type and is helping you to make the words. This used to be confusing to me as well, If you play a little with the buttons you will get it. Try to set in for multitap, it is a little easier.
Artgirl
Is there a scheduler function in this phone?have been unable to figure it out
Yes, use the native calendar, there are lots of features built in for appointments, meetings etc.
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
On the LG KP500 can you get a text alert of an appointment?
Set your appointment through your calendar. It will indicate when you wished to be notified and how long you want to be notified. If your worried about the sound of the alert when you receive your appointment notification, then change the default sound within your settings.
5helpful
3answers
LG KP500 Cookie bugs - Calendar Alarms and Sync
I have a lot of problems with the calender. when I first got the phone, a week or two ago, I put my work houres in it, and the whole week, no alarm. then weekend came and a small icon above of a small calender appeared, and the whole weekend it kept on going off 5 times in a row at 7.30, the time I needed to leave for work in the week, when it didnt went off at all O_o today, I had to leave at 8.30 and it went off at 8.30 but also at 7.30 again, while that's not an alarm in my calendar for today.. after work my cookie suddenly went out, I had to take the battery pack out to "reboot" it, now the calender icon is gone, I wonder if it will go off at 8.30 tomorow like planned or if it won't go off at all anymore again..
Another thing I noticed is, that when I put in a date from one houre to another is that it doesn't state the correct houre (when I put in 8.00 to 16.00 it shows 00.00 to 16.00) I put in until I open the actual appointement.
strangely enough, my cookie just lighted up it's screen as if I touched it out of itself and even more strange, the calendar icon up there is back..!
E900 calendar
no you can not....you will need to delete old meetings and dates on your calendar
Hot sync doubles appointments
I went into the HotSync Manager and changed the settings to Desktop overwrites handheld. That did the trick!
4helpful
Editing private appointment of a shared calendar
In your boss outlook do the following.
Tools --> Options --> Delegates
Select the delegates and click permission and enable check mark "Delegate can see my private items"
1helpful
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
