SOURCE: Gyration keyboard goes to sleep too quickly and then....
This sounds like an internal failure on the keyboard. It should not go to sleep. By removing the battery you are effectively resetting the internal logic. If the status light is on all of the time it may think it has (or have) a key stuck and is timing out to conserve battery life. If that is not the case it is time to contact Gyration Technical Support.
SOURCE: gyration keyboard modelgc15ck
if you have the installation cd try reinstalling it or try to install it on a nother computer to see if in indeeds does fully work
SOURCE: all of a sudden my gyration wireless keyboard won't work
LOOK IN THE CONTROL PANAL LOOK IN THE FOLLOWING FOLDERS, DEVICE MANAGER,NETWORKING AND SHARING, PROBLEMS & REPORTS, SYNC CENTER,
CHECK THE FIREWALL AND OR THE SECURITY CENTER, THE SECURITY CENTER MAY OFF BLOCK THE COMMUNICATION TO THE REST OF THE COMPUTER SOIT STOPPED WORKING
LOOKING FOR ANY TYPES OF MARKS, GREEN MARK IS OKAY AND WORKING FINE.
WHEN IN THE DEVICE MANAGE CHECK FOR UPDATES
ROD THE CANDYMANGANDY
SOURCE: Certain keys on the Gyration GC15CK keyboard have stopped working
If this is hardware problem, it'd be hard to repair. I don't mean it's not repairable, but what i mean is i don't recommend since repairing a keyboard and purchasing a new item will cost you more or less the same.
Well try this, Press Fn + Numlock (simultaneously on both the keys) on the keyboard and check if it helps or not [press once and then type the malfunction keys, if not press twice or thrice]. Most keyboard with Fn key's functions can be deactivated or activated with this key combination.
Good luck.
Thanks for using FixYa.
