Dell 1700 Laser Printer Logo
Posted on Jan 26, 2011
I keep getting burn marks along the edge of the paper on my Dell 1320 Printer. Can you tell me Why? thank you
4 Related Answers
Anonymous
  • 3587 Answers
  • Posted on Feb 06, 2008
SOURCE: Dell A940. Black ink on Front Edges of Paper
fuser is unhappy. Got a warranty?
Cameron Scott
  • 105 Answers
  • Posted on Mar 27, 2008
SOURCE: Repetative mark along right side of printed page.
Roller is misaligned somewhere or gear is broken. It will repeat every several inches depending on the diameter of the roller and the section that broke. A small section break that repeats every three inches indicates gear malfunction on a roller whose circumference is approximately three inches.
Anonymous
  • 50 Answers
  • Posted on Jun 16, 2009
SOURCE: Dell AIO 942 leaves blank strip along left edge of paper
It needs to be cleaned.
Anonymous
  • 137 Answers
  • Posted on Aug 09, 2009
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
1helpful
My HP LaserJet 1320 is showing an Orange Light ( Exclamation mark inside the Triangle) and i could not make any printing... It's keep showing that problem after restart the Printer. Can anyone give me some...
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Black marks along the edge of paper
there is probably ink on the rollers. get some paper and just keep feeding it till the black marks stop. and RECYCLE the paper that you fed. DO NOT throw it out
15helpful
3answers
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
2answers
HP lazerjet 1320
if your roller mark seems grayish it could be cause by a dirty roller in the paper path, open up your printer and clean with alcohol, there were some cases that the rollers were somehow softened and causing mark along the prints if this is the case you need to send thi to a tech for a part replacement
2helpful
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
