can you explain whats the problem with your remote at the time.
ok
hi,
if want to know how to program the remote for your equipments, then do the following.
1. Turn on the component that you want to set up.
2. Press and release the component key you would like to configure. The red LED will blink once.
3. Press and hold the "Setup" key until the red LED blinks twice, then release.
4. Enter the first 4-digit code number for the device you are trying to program. The LED will blink one on each digit entered, except for the last digit where it will blink twice to confirm that a valid code has been programmed.
5. Now test the code by pressing the "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 3 and use the next 4-digit code listed.
ok
hi,
if u need the chaet code here is it ,
Result Code
Third person view - behindview 1,
Unlimited ammunition - mpcheat paramsammo 1,
No clipping mode - mpcheat ghost,
Disable no clipping mode - walk,
Weapon select - mpcheat changeclass [weapon name],
Start game alone1 - start [level name],
Spawn indicated item or NPC1 - summon [item or character name],
Freeze game play - playersonly,
Remove all characters - killpawns,
Make some spawned NPCs walk - walk,
Single player map select - open [map name],
ok
hi,
before giving chaest code u have to do this.
Use a text editor to open "armyops.ini" file in the system folder of the game
directory. Find the phrase [Engine.GameEngine] and add this line:
bMPCheats=Enabled 2 .
Now you can press the TILDE key while playing to display the developer console.
ok
hi,
if u need any more assistance feel free to contact me through fixya.
ok
hi,
if need to know more about cheat code go to this linkhttp://cheatcodes.com/
hi,
cheat codes are those codes which you can use for win the games.
ok
Hope this helps. Please rate my response.
Thanks.
Have a good day.
