HOW
TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do
not use abrasive or harsh cleaners such as window sprays, scouring
cleansers, flammable fluids, cleaning waxes, concentrated detergents,
bleaches or cleansers containing petroleum products on plastic parts,
interior and door liners, or gaskets. Do not use paper towels,
scouring pads, or other harsh cleaning tools.
How
do I clean and care my stainless steel surfaces such as refrigerator
or any other stainless steel made appliance?
Avoid Citric acid
-it
can discolors stainless steel. To avoid damage to the finish of
your stainless steel appliance, do not allow these substances to
remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS. If
you want to clean safe and keep the sparkling steel you can purchase STAINLESS
STEEL WIPES this wipes is ideal for cleaning food spills,grime and
stains leaving surfaces shining like new. This wipes is for stainless
parts only make it sure this stainless steel wipes to come into
contact with any plastic parts.BUT
THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH
CLEAN WHITE CLOTH.
NOTE: Just
because a cleaner is a liquid does not mean that it is nonabrasive.
Many liquid cleaners designed to be gentle on tile and smooth
surfaces still damage stainless steel.
SOURCE: Maytag MZD2766GES Side by Side Refrigerator
Not actual stainless steel or the magnets wouldn't stick then all those frige magnet companies would go out of business. Maytag should make a cleaner/protector spray or something that will clean that up. Even the DIY stores like Home Depot or Lowes, etc. should have that type of cleaner. Naval Jelly can work but test in on a spot that won't show in case it stains the finish more than helps remove the rust. And yes, that would be cosmetic issue not a warranty item usually BUT read the extended warranty yourself to see if there is a loophole!
