Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WATER KEEPS RUNNING AFTER A FLUSH. IF YOU TAP THE BLACK TUBE IN THE BACK IT STOPS. IT LOOKS LIKE AN ADJUSTMENT ON A SMALL BLACK PIECE ATTACHED TO THE TUBE. SHOULD THAT BE TURNED SLIGHTLY CLOCK WISE OR COUNTER?
Rich Carothers
Level 2:
  • Expert 65 Answers
  • Posted on Jan 26, 2011
Rich Carothers
Expert
Level 2:
Answers
65
Questions
0
Helped
18900
Points
140
Fluid master ballcock,counter clockwise,water level should be 1'' below overflow tube,you'll probubly have to adjust a few times (flushes) to get it right
1helpful
2answers
When we flush the toilet, water continues to flow through a small tube into a vertical tube that is next to the flange, I think that's what it's called the part that lifts up by a chain when you flush
conventional flush: push lever, chain lifts "flapper" over the hole to allow water to enter bowl. As water goes down in tank, flapper covers the hole to allow the tank to refill. The small tube that dumps water into the standup, larger tube is what fills the bowl back up. Otherwise it would stay in a low water position allowing sewer odors into the structure. If the water does not stop, your fill valve is not shutting off. Probably needs an adjustment. If adjustment does not fix, replay flush valve.
Nov 19, 2018 • Plumbing
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
When we flush the toilet there is never enought water left in the bowel after...do i get more water
Make sure the small toilet fill tube in the tank is still running into the tank overflow tube.
The toto toilet keeps running over the overflow tube in the tank. I cleaned the valve which worked for a while but now is back to running. Should I replace the gravity valve?
If you can lift the float arm and it stops the water flow into the tank then the float arm needs to be adjusted. The proper adjustment will stop the water flow when the level is between 3/4" and 1" from the top of the overflow tube. The newer style valves have an adjustment screw that is easily located and can be adjusted without any dis-assembly.
Feb 19, 2011 • Toto Home
The tank is filling to the top of the tube. How do I lower the level in the tank?
Adjust the float attached to the fill valve. Some simply slide up and down on a racheted adjustment bar. Others screw up and down for adjustment. Flush after each adjustment until the proper fill level is acheived. Make sure there is still a sufficient amount of water at a given level to flush the toilet properly.
Our topflush toilet will nto stop running, once it is flushed. Theflapper seems secure. Not sure about the fill valve part.
after flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Kohler tub drain wont hold water
It's a bit trickey but can be done. start feed the large metal tube into the drain pipe and jiggle it slightly untill it's in as far as can. That metal tube is actually the stopper, which keeps the water from running out. Visualize the drain as a plus sign with one part cut off, something like |--. When in the closed postion the tube blocks the cross pipe (--) and stops the water from draining. When open the tube is clear of the cross piece and water is free to flow out. Your have to play with the adjustment screw on top of the tube to get it just right.
Jan 26, 2010 • Plumbing
2answers
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
1helpful
Hot water tap - no pressure and splutters
Do you have your own hot water tank? or is there one serving many units? There is a 'dip tube' in hot water tanks, if it gets old it sometimes deteriorates and small parts of plastic get loose and will float around in the tank, if a piece finds it way up to the outlet then that might explain why you are getting the low water pressure. one wat to check is to twist off the aerotor on the end of your faucet, if there are any small pieces of white plastic then you will have to replace the dip tube and maybe even flush out the tank. it is also possible that a piece of plastic has traveled up the water line and it stuck in the faucet cartridge.
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
