This sounds like the treadmill is running an incline calibration. It will run to fully inclined, then to minimum incline.
It should not do this every time you want to operate the machine, but they will do it automatically if the operation of the machine is stopped by the power being interrupted..
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built-up energy.
Remove motor cover.
Verify that there are no lights lit on the lower circuit board.
Verify that all wires are securely and correctly placed on the lower circuit board, especially the large wire harness on the top of the circuit board with 12 different colored wires coming out of it.
