There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
Change all 4 of the filters, and wash the dirt container with soap, water and a little bleach.
The only other thing that would cause a bad smell would be the actual motor, but that would be more of a burning smell.
smells are usually from bacteria. I have seen this before and you can get O.K results by rinsing the machine with cleaning soloution. I like ****-n-span. try to use a cleaner that you like the smell of as it will leave a little of that smell behind. use the vacum in the wet type aplication and use it to **** up the cleaning solution mixed with warm water with about the same mix as you would use to clean a floor. then after the machine fills up let the cleaning solution set in there for 5 to 15 minutes. dump out the cleaning soloution and repeat the process with clean warm water. If it has gotten really bad then you made need to repeat the entire process one or two more times. I also take the pick up hose and clean it with some cleaning solution then rinse outside with a water hose.
Mixing white vinegar with water about a cup of vinegar and a cup of water ratio and let it steam through the mop. This is also good for steam irons and other appliances such as coffee/tea makers. The acetic acid in the vinegar will dissolve the calcium build up that blocks the steam ports and will not hurt plastic or floors. If you object to the vinegar smell, then mix a little lemon juice with the last cup of water and this rids you of the vinegar smell. I use the white vinegar to mop the wooden floors in the house.
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
