Jabra BT2080 Bluetooth Headset Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to connect jabra BT2080 to phone. says enter passkey?
Anonymous
Level 3:
Genius:
  • Master 1,637 Answers
  • Posted on Jan 26, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1637
Questions
Helped
290358
Points
4933
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Smart Electrohub
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 18 Answers
  • Posted on Dec 24, 2022
Smart Electrohub
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
18
Questions
0
Helped
1606
Points
55
Bluetooth is not finding devices
Bluetooth not being able to find devices is a long-standing issue that has plagued wireless device users. The problem was once fairly serious, but because of improved technology and overall better equipment, the issue has become less. However, there are still some points where people are unable to connect their Bluetooth gadgets to their smartphones or laptops, which is extremely frustrating. But there is no need to worry about that now. There are some solutions and methods through which you can avoid this problem.
First of all, reset your Bluetooth connection.
You can reset your Bluetooth connection by following the given steps:
1) Go to the Settings menu.
2) Select Bluetooth from the menu.
3) Tap on the name of the Bluetooth device you're trying to fix in the list of associated devices.
4) Tap unpair from the list of available options to remove it from your phone/computer.
5) Re-pair the device if necessary.
Why Bluetooth is not finding devices-Conclusion
Bluetooth problems are very common and these sometimes rise. This article can simply answer your question that why is Bluetooth not finding devices. You can easily resolve these problems by following the steps and methods mentioned above. These methods can surely save you from the struggle.
For more detailed articles/blogs please visit: https://smartelectrohub.com/blogs/bluetooth-is-not-finding-devices/
Hi . Where to purchase ear gels for a Jabra BT 2080 headset. thanks.
You can purchase ear gels for a Jabra BT 2080 headset from " http://shop.ebay.com/i.html?_nkw=jabra+bt2080+ear+gel".
Good Luck.
1helpful
How do i connect my headset jabra bt2080 to my laptop hp 620?
I also have laptop hp 620 and the jabra bt2080 which are working through a driverless bluetooth usb dongle v2.0 (China) after installing jabra pc suite_2.5.6. It is under my experiment as at the moment only the mic is working when you start windows speech recognition program. i am trying to get it working as playback device to listen music instead of headphone through jack.
2helpful
Can you sync a Jabra BT2080 to a Jabra A120?
Hi Bobby Smith1,
Im afraid that is not possible.
the reason is that the Jabra BT2080 is only ment to connect to a mobile device which is used for calls.
and the Jabra A120s is only ment to be plugged into a speaker device whilst connected to a mobile phone.
in fact both the Jabras work like a Normal headset, thus two are not able to be connected. only through a mobile device.
i hope this helps, good luck!
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dont have the pin code to link it with phone.
Hello,here is the code to pair the jabra BT2080 bluetooth headset with the phone,when it ask for the pin code,kindly type 0000 and you are good to go.
take care.
1helpful
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
