Well most probably its FL error code it means failure to lock. Try unplugging the unit for 60 seconds to reset the control board and then plug it back in and see if it will reset. If not, then you will need to replace the door latch assembly. Try pressing STOP/CANCEL to clear the display. If further you have the same problem then you need to change the door latch assembly.
Good Luck!!
Thanks for using FixYa!!
SOURCE: my maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting
to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
