Computers & Internet Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant start my fifa 2011, shows me E001 - Computers & Internet
Anonymous
Level 3:
  • Master 943 Answers
  • Posted on Jan 25, 2011
Anonymous
Master
Level 3:
Answers
943
Questions
0
Helped
163035
Points
2880
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Giselle
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Feb 26, 2019
Giselle
Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286163
Points
2407
FIFA 19 Coins, FIFA Coins and FUT Coins are available on https://www.fifacoin.com, if you need some for your team, you should have a view here, good luck to you
I CANT PLAY FIFA CAUSE OF E001 MESSAGE !! WHAT SHOULD I DO ?
E001 is cause by the paper jam in fuser section.check the fuser section for proper drive.some times the bush of the lower pressure roller moves from its slot and that cause E001.so disassemble the fuser and have a gud look at it.
3helpful
2answers
E001 when playing fifa 11 on my pc
This error (e 001) generally occurrs when your graphic card is not supporting FIFA 11. This issue can't be removed unless you get a better graphic card.
If you want a better graphic card, you can consult THIS website.
I hope I helped you! Thank you for using FixYa!
2helpful
When I tried paying my fifa 11 on pc and when I clicked play a new window opened and it said E001. What does it mean and can you tel me what to do to sort the problem. thank you
E001 error when playing FIFA 11, means that your graphic card is not supported (does not meet the games hardware requirements) in playing the game!! Majority of the onboard graphics card do not support very high graphicsPC games eg FIFA 11. ( Updating your DirectX or Graphics cards drivers will not help.)
In order to play the above PC game you have to get a better graphic card which support at least the "Shader Mode 3".
Hope it helps.
4helpful
2answers
Fifa 11 starting time say e001 error
E001 error for FIFA 11 - Means your Graphic card is not supported in playing the game. You need to upgrade your Graphic card which support at least the "Shader Mode 3" function.
Most of the onboard graphic cards does not support this function and you get the E001 error when you play the game. Updating your DirectX or graphic card drivers is no help at all because is a hardware compatibility issue.
Hope it helps.
1helpful
2answers
When i try to play FIFA 2011 it keeps showing e0001
FIFA 2011 it keeps showing e0001???
Your Graphic card does not support the FIFA 2011 game.
Get a better graphic card which support at least "Shader Model 3". Most of the intergrated ie onboard graphic cards do not support the game.
Hope it helps.
7helpful
2answers
E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
2answers
When i open fifa 11 in my pc then it displays the e001 error
please download fifa 11 patch and copy to game folder it will be solved bye
1helpful
2answers
I installed fifa 11 and when i try starting the game i get error e001 ... when i try to run fifa 11 i get an error message saying E001.how to fix this ...
Error e001, starting the game fifa 11
Most probably your video card does not support "Shader Mode 3 or higher".
Get a better video card.
What are your system specs? Have you updated your graphics card driver and installed the latest directx redist. In the fifa11 zip file there is a redist folder, make sure you install everything in there as well. Also, try updating your sound card driver, it may be conflicting.
Take note**
Chipsets used in models
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350 and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
2helpful
2answers
In fifa 11 demo . when i start E001 create problem so ask me how to start.
Go to my documents / Fifa11 / fifasetup.ini and open it / change the "RENDERINGQUALITY TO 1" default is 2 . It solved my prob :) cheers
Grand Canyon Tech
Grand Canyon Tech
