Apple iPhone 3G Logo
Posted on Jan 25, 2011
Iphone not recognized in itunes - Apple iPhone 3G
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Feb 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
4038
Points
53
Install latest version of Itunes.
1) open "run" from the start menu, and run "services.msc".
2)find "Apple Mobile Device".
3)In the "status" column it will tell you if the process is started or not, and the "startup type" column will tell you if the process will start automatically when windows starts. Set the status to "started" and the startup type to "automatic".
4)To do this right click on this process, and then click on "Properties"
5) In the "general" tab find the "startup type" drop-down arrow menu and make sure "automatic" is selected. Select it if it is not.
6) Also in the general tab check the "service status". If it does not say "started" then click the start button.
7) at the bottom of the properties window click "apply"
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
2answers
Jailbroken/bricked Iphone w/tmobile sim card
If the Iphone works, all you have to do is reinstall Itunes.
When i plug my iphone 4s into my pc with itunes running it doesnt recognize the phone, cable is good pc makes sound when i plug in
There are several methods you can try to fix this issue. One of them shows below.
How to Fix iTunes Not Recognizing iPhone in Windows 10 Before You Begin:
  • Make sure that you have the button Trust this computer on your iPhone when connecting to your PC.
  • Make sure that you have installed all Windows updates. This is to make sure that your computer device drivers are up to date.
  • Make sure your iPhone USB cable works well.
  • Make sure your iOS device is turned on.
  • Make sure you have the latest version of iTunes installed.
  • Now, the following solution may help you fix the iTunes issue if you found that your iTunes does not recognize iPhone in Windows 10 computer.
    Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
    Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
    Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
    Step 4. Then choose "Let me pick from a list of device drivers on my computer".
    Step 5. Click "Have Disk..." button.
    Step 6. Click "Browse".
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64.
    If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Then you need to install the driver for your Windows 10. After installing, unplug your iPhone, then reconnect it using USB cable. Open your iTunes and see if your iPhone can be detected or recognized by iTunes.
    For more details, check: How to Fix iTunes Not Recognizing iPhone in Windows 10
    My iphone disabeld connect with itunes
    If you mean iTunes on your computer can't recognize your iOS device, you can refer to this tutorial to fix it: iTunes Cannot Recognize iPhone telling you some basic tips to fix this connecting problem of iTunes.
    Nov 18, 2015 • Cell Phones
    How do i copy ipad to ipod
    It's not a complex task. Actually, there are several ways you can resort to copy iPad to iPod. Just follow below steps.
    1. Run iTunes and choose "Edit > Preference > Device > Prevent iPods, iPhones and iPads from syncing automatically" at the upper left corner of the window.
    2. Plug the old iPhone into computer via the USB cable, and iTunes will recognize your old iPhone. Right-click the name of your iPhone and choose "Back Up Now" in the drop-down menu. iTunes will create a backup of your iPhone, and you may have to wait for a while until iTunes finishes backing up your iPhone.
    Restore from iTunes Backup
    3. Disconnect the old iPhone and plug in the new iPhone. After iTunes recognized the new iPhone, and at the "Set Up iPhone" screen, select "Restore from iTunes Backup". >5. Select the most recent backup you just made from the restore menu in iTunes, then click "Continue". When the restoring process is done, the new iPhone will restart. And you have finished to clone iPhone to new iPhone.
    When the restoring process is finished, the data will be imported into your new iPhone, but the media files, such as music, videos and so on, won't be transferred to the new iPhone. If you have purchased albums in iTunes Store, you will have the songs in your purchased history, and you are able to download the songs on your new iPhone directly by entering iTunes Store with your Apple ID. You'll need good Wi-Fi connection to finish the task.
    For more methods, check: How to Clone An iPhone to New iPhone
    Itunes could not connect to the iphone because an invalid response was received from the device
    There are many reasons why iTunes will not recognize your iPhone or iPad, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone or iPad you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
    For more details, check: What to Do When iTunes Not Recognizing iPhone
    I Tryed To Connect It Too ITunes. And , It's Not Popping Up Nothing ; It's Just A Black Screen . What Do You Think Is Wrong With It ?
    1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
    3. Reset or restore your iPhone for a try, this way can fix many general iPhone problems. 4. Update your iTunes to the latest version. Plug in your iPhone . If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPhone .
    5. You may try this iPhone transfer, it's a nice iTunes alternative that can help you upload music and video to iPhone , I always use it to sync my iPhone when my iTunes can't recognize my iPhone , it's easy to use and works pretty well. If you have any other questions, feel free to email me.
    Itunes or windows wont recognize iphone 3g
    uninstall itunes and the other components such as quicktime, apple mobile device support, apple application support,apple software update and bonjour.
    • go to your control panel and add or remove programs(win vista or 7) or programs and features(win XP)
    • remove the stated programs from above, restart your computer
    • visit apple.com/itunes and download iTunes and install.
    • plug your iPhone in and then it will load the driver for it and then be recognized again by your itunes and computer
    Says connect to itunes but i cant because im in another state
    It's a common issue. You can check below steps to fix it.
    How to Make iTunes Recognize iPhone There are many reasons why iTunes will not recognize your iPhone or iPad, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone or iPad you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
    For more details,check: What to Do When iTunes Not Recognizing iPhone
    2helpful
    ITunes doesn't recognize iPhone SIM card
    u pls jailbroke the iphone with redsn0w , then it will be
    Top Apple Cell Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ADMIN Andrew
    ADMIN Andrew
    Paul Bade
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
