Internet access setting for Motorola RAZR V3X :
1. Go to menu => Web Access => Web Sessions => new entry 2. Fill in a account name 3. Select Access Point settings 4. Set service type to
WAP 5. Enter GPRS access point (APN)
6. Enter User name and Password 7. Select myGlobe
GPRS. 8. Press menu 9. Select set default
Note : you have get valid names /codes form service provider of number 2,5,6. Different operator will has different setting.
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV / Blu- ray / HD DVD / DMA
You need a DVI-to-VGA converter if you only have VGA input to your monitor. If your monitor accepts DVI connections then you can connect the DVI out from STB to your monitor.
If you have different input options on your TVs, you could run the second TV with the Y, Pb,Pr component outputs along with the analog audio from the STB. However, remember the STB will only support ONE output video format. So both TV will have to be set to the same video format (720p, 1080i, 480p, etc)
contact your service network provider to activate your GPRS connection, the gprs on your phone/unit is not been yet activated. if the gprs is activated go to web access then websessions menu. to check if theres a new menu that installed that indicate ur gprs activation
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
