Connect a PC to the router either by wireless or wired connection (You need a standard ethernet cable to do this connected to port 1) and then open a web browser. In the browser go to 192.168.0.1 and enter 'Admin' as the username and leave the password field blank (default settings) (If you have changed the password and username, you can use the new ones or if you forgot, you can press the router reset button for default confirmation to return). On the Network Settings tab, turn off 'Enable DNS Relay', This is actually the easiest way to disabled the NAT. Once you disabled it, you can use your router as a Network Bridge. The trick is to disabled the WAN feature which is the normal function that the router does during NAT OR DNS. If none of this information is helpful, why not try calling their technical support, I've had nothing but (relatively) good experiences with them. The phone number in the US is 877-453-5465
