Dishwashers Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bit of an electrical burning smell which may get worse on the drying cycle? also, how do you set the self diagnostics running?
William Dehn
Level 3:
  • Master 318 Answers
  • Posted on Jan 25, 2011
William Dehn
Master
Level 3:
Answers
318
Questions
0
Helped
112869
Points
1021
Electrical burning is a bad sign. Unplug it and have it serviced! When you smell electrical burning that mean the resistance on the circuit has increased beyond the acceptable thresholds and the safety features such as ground fault, fuse and breakers are not operating. This is the cause of 100% of electrical fires! Take it seriously.
Our LG microwave is only 1.5 years old and cooks fine but has recently started to emit what smells like an electrical burning smell.
if smells like something then something is burning stop using answer about can it be fixed is unknown till diagnosed
Beco cond dryer DRSC 68 W When drying cycle ls on l hear an electric trip sound followed by a wire burning smell
If you EVER smell that again, unplug, unload(dry or not, lives may be at risk), preform a thorough check and identify the smell. Then buy a replacement part and check ALL the wiring. Really I cannot stress just how dangerous this is. In my opinion a new dryer would be fine.
Nov 07, 2014 • Dryers
Burning Smell from washing machine! Brushes?
2cm seems short for brushes, probably your problem.
My Kenmore Ultra Care Dryer is having trouble starting. I'll push the button to start , it makes a noise like it is starting, but it may or may not start the cycle. If I keep pushing the button, it starts...
Sounds like you have a bad drive motor.All the symptoms point to this, intermittent no start ,noisey when it does run, and most of all burning smell,what you are smelling is the covering they use to protect the windings of the motor, this could be a potential fire hazard I would get this repaired soon or if the unit is old enough to justify replace it
1helpful
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
2answers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Kenmore electric dryer won't start. #63841
Most likely the vent to the ouside is clogged. That would cause the initial not drying properly problem.
If the exhaust is clogged, the moisture cannot exit properly, and it ofcourse, cant dry properly.
This also caused heat build up because the vent being clogged wont allow proper airflow over the element/s and it then starts poping limit switches or worse, burning elements.
The smell was probably an overheated element resulting in the popped switch.
Some units are auto reset. Just disconnect power and reconnect.
Some are manual reset, you have to locate it and push the button. And still others are one time trip, and must be replaced. These can sometimes look somewhat like a fuse.
Trace out the wires (with power disconnected) from the elements untill you find all the limit switches. Disconnect both wires to each side of the switch and see if there is continuity accross it. If yes (the switch is closed) it is good. If not, replace that switch. Be sure to check them all if there are multiples in your unit.
Jan 06, 2009 • Dryers
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
1helpful
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
