Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray Logo
A
Anonymous Posted on Jan 25, 2011
I"m removing and replacing a
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 119 Answers
  • Posted on Jan 25, 2011
Anonymous
Expert
Level 2:
Filmmaker:
Answers
119
Questions
0
Helped
65600
Points
219
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.
Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
1helpful
The water leaks from the top of the valve when the handle is fully opened.
You may have to put a new repair kit in faucet, but you might try tightening the adjusting nut under the handle. Loosen set screw in handle, and remove handle. There is a nut there with 4 notches in it. Delta gives you a combo allen wrench/spanner wrench for this. Try to tighten this nut. If you can't you can buy a new repair kit for this valve for about 10.00 that comes with wrench
Hi While I try to rotate the tap , the whole base is rotating with it ( delta 470 ss)
A "basin" wrench will be needed to get up under the sink/faucet base to tighten the nuts that hold the faucet in place. It's a simple job but requires the agility of a contortionist to get at.
2helpful
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
1helpful
2answers
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Top Delta Faucet Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
