Re: My car 2001 spectra kia is stuck on Parking it wont...
Check to see if your brake lights are working .if not look for blown fuse or brake light switch or bulbs their should be a override slot or procedure to release from park.release solenoid is not working.
Beside the gear shift lever , there is a round hole. It has a cover over it, pop cover up, use long rod put it in hole and gear shifter lever will move with rod still in hole.Beside the gear shift lever , there is a round hole. It has a cover over it, pop cover up, use long rod put it in hole and gear shifter lever will move with rod still in hole.
You can't post conmments that contain an email address.
The pins could be in bad section use a tester to find which sections is possitive ground and acc. The move pins by pushing in the pulling out in one motion then move to that
