Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Click this link directly for user manual:---
SOURCE: LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
SOURCE: LE light is on and washer wont run. Model LG wm0642hw
I would suggest unplugging for 12 hours. If you plug it back in and it works again then order a new main control module. If it still doesn't work after unplugging for 12 hours then you probably will need a new hall effect sensor. check out pa rtstore . com for parts. Good luck!
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
SOURCE: error LE
The "IE" code indicates a water inlet problem. If the correct water
level is not reached in eight minutes, this code is generated. Check
the water inlet valve. Unplug the machine, turn off the water, and
remove the water supply hoses. Check the small metal screens inside the
openings on the water inlet valve. Make sure they are clear of rust or
debris. Check the solenoids using a multimeter or ohmmeter.Check for
continuity. A lack of continuity means a bad solenoid and the water
inlet valve assy will have to be replaced. I'll attach a photo for
reference. Sorry for your trouble and I hope this helped. Best wishes.
SOURCE: I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Yes, I been doing for the past year or so, it helps me alot but sometimes it just got over
wellming . ALOHA for the information I need to get a manule.
