Computers & Internet Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime i turn my computer on it launches into startup repair (recommended) Windows loading files? Starup repair is checking your system for problems do you want to restore your computer using system restore sometimes, it shuts down unexpectedly when still asking launch repair startup then most of it there's a sound inside my COMPAQ 510 sounds like "tik tik" and that signalize that it will shut down as in off. What will I expertly do?
Duane Wong
Level 3:
  • Master 6,826 Answers
  • Posted on Jan 25, 2011
Duane Wong
Master
Level 3:
Answers
6826
Questions
6
Helped
2861926
Points
20234
OK, I would try to restore to the earliest date possible, or Recover to original state of computer from factory. The latter is more radical than the former, but it will guarantee that any corrupt files are eliminated.
2answers
Computer failing to start
Your Operating System maybe corrupted. If you have the installer that it came with (usually a CD), you may need to use that when repairing. Your computer should extract the missing/corrupted files from the installer
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
2answers
1helpful
2answers
Laptop won't starup (Black screen displayed) Help me please!!
Try this.
Turn the computer on and immediately press and hold the F8 key.
On the Advanced Boot Options menu, choose Repair Your Computer.
When you reach the System Recovery Options menu, choose Startup Repair. You already did that, but try it again.
If that doesn't do the work, go back to the System Recovery Options menu and do a System Restore.
You can use the Bootrec.exe tool in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista or Windows 7:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
Note When you are troubleshooting startup issues by using the Windows RE, you should first try the Startup Repair option in the System Recovery Options dialog box. If the Startup Repair option does not resolve the issue, or if you must troubleshoot more steps manually, use the Bootrec.exe tool.
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  • Put the Windows installation disc in the disc drive, and then start the computer.
  • Press a key when you are prompted.
  • Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  • Click Repair your computer.
  • Click the operating system that you want to repair, and then click Next.
  • In the System Recovery Options dialog box, click Command Prompt.
  • Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Thank you Sir, Have a nice day.
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Acer extensa 4420 laptop, not working
when windows starts up it loads my files. but when its loading files. it cant load those files, so its stop working and shut down. if u r not expert. reload yor cop of windows.
2answers
ACER labtop
If it askes for a password try the password\
admin
and then press enter If this does not help try f8 safe mode
if that fails get the operating system CD or the recovery CD that belong with the macking.
After theis by a backup and hid it from everyone that wants to use it/...
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Grand Canyon Tech
Grand Canyon Tech
