Attempt changing the option by using the menu button on the tv (changing it manually).
the tv does not have a menu button its a tv/dvd combo so it just has the power button the volume buttons the channels button and then the regular buttons for a dvd like the fast forward, rewind play ,stop
Thats a problem. Emerson does not recommend universal remotes (go figure). Mainly this is because the codes will not work properly with the remotes, so some buttons may not work. You will probably need to contact Emerson for a replacement remote.
how much do you think that will cost ?
I am not sure without knowing the serial number (part number) of the remote. Prices can range from $25 (OEM replacement websites) to maybe $50 (from Emerson).
0154, 0236, 0463, 0180, 0282,
0178, 0179, 0038, 0177, 0280
The Comcast Custom 3-Device universal
remote control is preprogrammed at
the factory to operate the Cable Box
supplied by your Comcast system, an
RCA TV, and an RCA VCR (in the AUX
mode). To control devices other than
default brands (excluding the Cable
Box), perform the below steps; otherwise
skip this section:
1* Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2* On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3* Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4* Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5* Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6* Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
OK
