Leviton countdown timers have additional wire that powers internal electronics.
Leviton timers have red-black-white-green wires (or blue-black-white-green wires)
1) Regular single pole switch has 2 insulated wires. One of these wires is Hot from breaker, and the other goes to Load (fan)
2) Timer green wire connects to bare ground as you know.
3) Hot from breaker connects to timer black wire.
4) Load wire connects to timer red (or blue) wire.
5) Located in back of box are white wires that are twisted together and covered with wire nut.
These are Neutral wires. Connect timer white to these wires. This will power timer electronics.
6) If box does not have Neutral wires described above, then connect timer white to bare ground along with timer green wire.
7) Turn power ON and try timer countdown.
If timer does not work, then reverse timer red and timer black wire.
8) If box does not have neutral wires: Image on link below shows similar Intermatic timer:
Image applies ONLY when Neutral is not available.
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Search shows Leviton 6161 is "incandescent dimmer" and not a countdown timer.http://www.amazon.com/Leviton-6161-I-Dec...
To see cross-section of countdown timers: http:waterheatertimer.org/Countdown.html All timers shown on 2nd link will work for bathroom fan (not heavy enough for whole house attic fan except FD and FF series). You can buy inexpensive countdown timers at local Home Center. Notice each countdown timer has times printed on face of timer. They are displayed with the timers. Or buy Leviton 6260 60-minute or 6230 30-minute on-line. Wiring for countdown is shown in first response.
unfortunately, I apparently gave you the wrong item description number. The correct number is Leviton Decora single pole 5 button Countdown Timer, catalog No. 6161T. 500W incandescent (lighted) 15A, 120VAC, 60 Hz.
I'm trying to use it to control a bathroom fan, but it doesn't power the fan with sufficient energy to make it rotate. Does this timer work for fans?
