Its busted.
Try resetting it as a last resort, unplug the AC, wait 1 minute, then
plug back in. If that doesn't work, its in need of professional
service.
On my Akai LCT2715---- Ok, I had the same problem with locating USER MODE (even called Akai service HELP and that person didn't know anything)!!! even tho we looked through manual just got TV back from putting $184 in Capacitors repair (PUT IN NEW NICHICON CAPACITORS) from the standby button not woking just flashing from the Power Supply gone bad plus 2 main capacitors other than power supply that were bad. Works great now. For the USER MODE look on the remote in the bottom black area repeatedly push the P.MODE. You should have full function to adjust all in menu list WE DID.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply. I service these power supplies, for more info write to [email protected]
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
try going to www.replacementremotes.com to see if they have the exact remote as some universals remotes don't work the set completely . Or you can see if they have the replacement remote that would work for your set .
Here is what I found out. I had this same problem. I have cable TV and the signal coming into my house was not very strong. They 'boosted' the signal and this problem stopped. Along the way, they tested that the cable line had been passing through a splitter, so that to the house the signal was good, but by the time it passed all of the splitters, the signal was not strong enough. Now all is well and the problem does not happen anymore.
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
