Mine flashes 5 times and sais operator error
I have tried EVERY solution I could find on the internet - NONE worked.
This DID work:
Remove printhead - get large plastic cup or tupperware bowl that is wide enought to
hold the printhead - Fill cup or bowl to top with HOT water. Place printhead in to cup or bowl so that the water covers the top of the silver circles for each color on the printhead - The ink in the water will go into the water. After 2-3 minutes empty the water and repeat - repeat until water is close to being clear - place printhead on wadded up toilet paper (bottom of printhead on paper) on press slightly down for 30 seconds or so - paper should have no colors or just a smidgen of a color on it - Gently use toilet paper to remove EXCESS water - DO NOT try to dry every part completely - let printhead sit on toilet paper overnight - place in printer - add ink cartridges- go to printer - properties - maintenance and run nozzle check until it looks good (2 or 3 times) - do a print alignment and VOILA!!! - You just saved $100.00 or so. It worked for me
I tried all the reset codes and so forth you might find on other otherwise useful forums, and i have successfully modded 5 of these to print on DVDs, but this "operator error" and five yellow flashing lights was a tough nut to crack. I was about to give up and toss it when I tried one more thing and it works!
With the cartridges removed and the printhead carrier in the central position, press the empty printhead's back gently but firmly about a dozen times back against the printhead carrier, pushing it in toward the rear of the printer. I think this may help improve a bad contact between the half a dozen or so rows of little metal contacts on the printhead and their corresponding protruding little metal pins on the printhead carrier. It feels a little spongy (you can feel some give) as you push it in toward the rear of the printer and it gently springs back forward.
This solved it for me. I thought I'd share my idea and successful solution, and I hope it helps you, too.
get operator error message Ireset but still does not work Don
Canon S9000 gave me an Operator Error and said to press the resume button. This doesn't work. I unplugged both plugs as canon support told me to do, and it still comes up with 7 yellow flashes and 1 green.
how many time are flashing the orange light?
printer shows the operator error when pressing the button.how to solve this problem?
