Fan switch ? Blower fan or engine cooling fan ??...I presume you mean the blower fan speed control switch.
On top of the battery under the hood, is a set of Green 30Amp fuses. These burn out the holder and a/c no longer works.
If so, by pass fuse with a replacement/repair '' in line fuse'' of 30 Amps from you local parts store.
Other reason fan not working is failed fan resistor under glove box near fan housing....although this is usually low speeds not working by HI does.
If you have the non electronic a/c system, the a/c rotary switch in the panel burns out often.
THIS SWITCH DOES NOT TURN AT ALL...IT ONLY GOES BACK IN ONE WAY.....DOES ANY ONE HAVE A SOLUTION??? THE BULB IS STILL LIT........
