2003 Honda CR-V Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine light came. Computer sencer said it isP1259
Engine light came. Computer sencer said it isP1259 What is p1259? How can solve that problem
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
  • Posted on Jan 24, 2011
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065350
Points
207
Hi and welcome to FixYa!
P1259 means VTEC system malfunction. Low oil level and a bad oil pressure switch for vtec can cause this. It can also be a faulty vtec solenoid.
Hope this helps and thank you for using FixYa! Have a good one!
Check engine light came on throwing two codes P1167 and p1259 I need help!
Oxygen sensor is not communicating with the ECM and the Vtec code is for the internal valve timing and cylinder shut down after reaching highway speeds. Dealer ship repair or a shop you know has the tools to fix the internal engine parts as well as the electronics that control the engine.
Code p1259 without CEL coming on. found out by the mechanic plugging it up the the machine.
buy it,this is the problem, P1259 VTEC MALFUNCTION CODE FOR HONDA 2 3L VTEC ENGINE ,replace it for about 150 bucks. 7775251b-bbeb-4468-b735-a02ee837616f.jpg OES Genuine Cam Adjust Solenoid for select Acura/Honda/Isuzu models, http://www.amazon.com/gp/product/B001G7ODLS
Amazon com OES Genuine Cam Adjust Solenoid for select Acura Honda Isuzu... ,,your check engine light also needs to be replaced,it was probably taken out in order to sell the car,it is illegal to do.
1helpful
O2 sencor
What kind of vehicle, and what is the actual code ?
1helpful
Check engine and TCS light on. code P1259. can not rpm 3500
P 1259 VTEC oil pressure switch circuit or vtec solenoid or valve,Here the situation you can be dealing with the oil pressure switch or the VTEC solenoid or valve,8_10_2012_5_08_54_am.jpg
I have a 1998 Honda Accord the service engine soon light came on. I failed inspection and was told I had a Diagnostic trouble code P1259.(1) What does P1259 trouble indicate. (2) How do you turn off the...
p1259 is a problem with the VTEC system. this system is for improved performance at higher rpm's. oil can get sludged up and clog the system, or the VTEC solenoid can just go bad. you can always have someone with a scan tool clear the codes to turn off the light, but until the problem is fixed, it will just keep coming back on
I have a 2000 honda accord ex... My engine light is on and throwing the p1259 code. It is not a Vtec engine... help. I just got the oil changed and the light is still on. However they put 10w30 in.. should...
The P1259 : is problem in the VTEC Oil Pressure Switch circuit or VTEC Solenoid Valve circuit.
check the wire on the VTEC Oil Pressure if it's loose.
1helpful
My Acura TL 1999 is showing check engine light, P1259
Check the oil level on level ground.
V-TEC valve open at the pre-set RPM is total depend on the oil to opening the third valve.
If the pressure is not at the right level then the lifting will not be completed.
The lift sensor will trigger P1259 to warn the driver for V-TEC malfunction
Please rate my answer if it's useful to you.
Thanks
MUSTGO
3helpful
I have a 2005 honda civic si recently my check engine light came on showing the following codes they are P1259 and P1166
P1259 is a code for vtec malfunction usually cause by a bad vtec solenoid, vtec pressure sensor, low oil level, bad connection. Was oil change done? May want to check the oil level. P1166 is a code for a primary o2 sensor 1.
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
