The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
SOURCE: pixma ip500 error message 5C00 - what does it mean?
I have the same message and print haed does not move at all.
I will pay for it to be fixed next week (after Easter) and let you know the cause.
Cheer's Steve
SOURCE: Error Message 5C00
4 times is usually Automatic
print head alignment
Set a
sheet of plain paper (A4 or letter) in the ASF.and adjust.
