Question about La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
    Brigadier General:
  • 8,546 Answers
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Posted on Jan 25, 2011
SOURCE:
I have a La Crosse wall clock, model WT-3102. It stopped running so I replaced the battery. The clock immediately moved to 4:00 and stopped. I left it overnight but it didn't move. I removed the...
Sounds like it is not picking up the radio signal.
Try placing it in a window overnight where the radio signals do not get obstructed.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 03, 2011 | La Crosse Radio Controlled Atomic Clock
It has a new battery now i can't reset the time it is a crane viceroy radio controlled fintan
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all LA CROSSE watch manuals. Rate me, please
Mar 30, 2010 | La Crosse Technology E. Howard Ambassador...
Hands started spinning and won't stop. I replaced battery - still spinning
Remove the battery and replace with a new one. Just because.
Depress the tab on the back of the clock mechanism firmly (it pushes in a button beneath it) 22 times. While you're pressing the tab, the hands will begin to rotate. They will stop at 12 , 4 or 8 o'clock.
Place the clock in a window where it will be able to receive the radio signal.
Next morning the clock should have re-set to U.S. Pacific time. Press the on the clock mechanism that corresponds to your time zone and you should now have the correct time again.
May 24, 2009 | La Crosse Radio Controlled Atomic Clock
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
Screwed up electronics in 2003 Hyundai Sonata
Sound like the vehicles ECU (electronic control unit) is acting up. All electronics are controled through this module as well as the features your car is programed with. Many manufacturers have different names for these modules but they all perform the same tasks. Your best bet is to bring it to a dealer where they can hook up a computer whith their diagnostic software in it to pinpoint the problem. All electronics in vehicles are controled by modules which are like mini computers.
Jan 11, 2009 | Hyundai Motor 2003 Sonata
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
492 people viewed this question
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
