If the compressor is overheating I would check the condensor fan and make sure it's turning. Sounds like you wouldn't have noticed this already though. Also, if the compressor is turning on for 5 or 10 seconds and then clicking off then your start relay is probably bad. Pull the relay off the compressor and shake it. If something is loose inside then it's bad. That is, if it's a whirlpool made kenmore. Kenmore doesn't make appliances they only brand them. The refrigerator could have been made by Whirlpool, Frigidaire, GE, LG, Maytag, Amana, or other. So, it's depenant on who made it.
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
by the time you have fixed any faults,you might just as well buy a new(er)more effecient f/freezer.cost you less in the long run(got mine from a garage sale,owners were moving far away....)
Good day, The shut off is due to the protective overload mounted on the side of the compressor to shut it down, if it can't start. On the side of the compressor is a cover box that contains the overload device, a start relay, and on some models, a start/run capacitor. These items can to a degree tested with an ohm meter, but it is wiser to take them to an appliance parts house for testing. If any are found defective, replace them. If not, the compressor has failed internally and needs to be replaced. Close to $400.00 if not more.
your freezer is short cycling which is bad for the compressor. Usually there is an internal overload in the compressor that automatically resets as the compressor cools. Check to see that all of the coils are clean and the small fan is blowing. this will make sure that the airflow correct. look for signs of oil around the compressor, the coils, and any connecting tubing. if you find oil, this is a sign of refrigerant leaks. the refrigerant is what cools the compressor and it wont run long in an overheated condition. it will finally fail in the open position and not come back on.(compressor overload switch) If this is the case you may replace it cheaper
