GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
A
Anonymous Posted on Jan 24, 2011
Ge stackable wsm2700DAWWW makes noise and not drying properly.
Anonymous
Level 1:
Champion:
  • Contributor 266 Answers
  • Posted on Jan 24, 2011
Anonymous
Contributor
Level 1:
Champion:
Answers
266
Questions
Helped
54348
Points
6
GE HAS A REARBEARING THAT GOES OUT OVER TIME .. NORMAL WEAR AND TEAR FROM USE COULD ALSO BE YOUR HEATING PROBLEM IF THIS IS ELECTRICAL DRYER TUB COULD BE GROUNDING ELEMENT
1 Related Answer
Anonymous
  • 266 Answers
SOURCE: ge stackable wsm2700dawww
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
1helpful
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
1helpful
Ge stackable wsm2700dawww Dryer making noise,maby belt,and not drying very well.
2helpful
My ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
2answers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Tub spins while during wash cycle
trust your memery it gos back wards as well
I currently have a stackable W/D made by GE in my condo. However, the Washer just broke and it would cost $500 to fix it. So the contractor suggested it might be better for me to just purchase a new one....
sears will give you 10% towards your next purchase if you call them out for the repair and decide not to do the repair. but will cost you the trip fee. depending on what is actualy wrong with the unit, every repair person is going to give you their own price. w/a model # and the problem all i can do is educate you on parts costs... hope this helps
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
