SOURCE: Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
SOURCE: Bulbs for infrared toaster oven
Blue Devil,
The bulbs are available from the Panasonic parts store (Google), however I called Panasonic service and they could not explain to me how to take the toaster apart or tell me how much the repair would be. I partially disassembled the toaster and still could not figure out how to replace the bulb. Sorry. Good luck.
Todd
SOURCE: Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
SOURCE: Model# 6058 toaster oven won.t
You need to remove the top cover and check for a bad fuse if no display. If you have display, then it could be a bad door switch, or a bad megaton, or na bad high power Diode.
