<span>MULTIPLE GOOGLE TALK IS POSSIBLE BY RUNNING THE GTALK WITH A SWITHCH CALLED /nomutex<br />THE FOLLOWING IS THE PROCEDURE FOR PUTTING THE SWITHCH TO THE SHORTCUT ICON:-<br />To edit existing Google Talk shortcut:<br />1)Right click on the Google Talk shortcut.<br />2)On the right click contextual menu, click on Properties.<br />3)Go to Shortcut tab on Google Talk Properties window.<br />4)On the Target textbox, add in the /nomutex to the end of the line so that it looks like below (or you can simply copy and paste the below syntax and replace the original).<br />"c:\program files\google\google talk\googletalk.exe" /nomutex<br />5)Click on OK.<br /><br />To create a new shortcut for Google Talk:<br />1)Right-click on the desktop or anywhere you want to place the GTalk shortcut.<br />2)Select New on the right click context menu.<br />3)Then select Shortcut.<br />4)Copy and paste the following line to the text box when prompted to type the location of the item:<br />"c:\program files\google\google talk\googletalk.exe" /nomutex<br />5)Click on Next.<br />6)Give the shortcut a proper name such as Google Talk or Google Talk Multiple or Google Talk Polygamy.<br />7)Click OK until you are done</span>
Download Google Talk from http://www.google.com/talk/
and run the set up file.
After downloading google talk, once you sign in to google talk, you can start sending and receiving IMs from google talk contacts.
To send an IM on Google Talk, first, select a contact and click on their Google Talk username. An IM window will appear addressed to your Google talk contact. You can type your message in the google talk IM window and press Enter on the keyboard to send your mesage.
Download Google Talk from http://www.google.com/talk/ and run the set up file. After downloading google talk, once you sign in to google talk, you can start sending and receiving IMs from google talk contacts. To send an IM on Google Talk, first, select a contact and click on their Google Talk username. An IM window will appear addressed to your Google talk contact. You can type your message in the google talk IM window and press Enter on the keyboard to send your mesage.
You can easily identify if it's the router or talk talk. Bypass the router and connect your computer directly to the modem and check if the same problem occurs. If it does, then the problem is talk talk. If not, you can login to the router's setup page by going to http://192.168.2.1 you can see there the MTU
Google talk allows you to "chat" to friends and other people that you havce emailed and that use gtalk. you can also talk to them if you have a mic and or a video camera.
It can save you a lot of money if you regularly talk to people over seas as it it free. It is similar to skype or live messenger or yahoo messenger
I purchased a Bratz talk back alarm clock for my daughter, however, she threw away the instructions. Can you tell me how to work the clock to hear it talk back or to activate the talk back voices.
