UNIT NOT COOLING ... LIGHT DOES NOT COME ON ... FAN NOT WORKING.
I REALIZE IT IS NOT AN "UNDER THE COUNTER UNIT" ... BUT HAS WORKED WELL IN A CONFINE SPACE FOR SEVERAL YEARS.
HAVE HAD UNIT FOR ABOUT 4- 5 YEARS
WOULD LIKE FIXING IT ... ANY SUGGESTION?
THANK YOU VERY MUCH FOR YOUR ATTENTION.
HVW18BSS
SE. NO. EAHA631206BB
MODEL: HVW18BSS
MFG 3/2006 - CHINA
60HZ / 1.95AMP
EMAIL: [email protected]
How does a car radiator fan work?
The engine cooling fan is designed to move air through the radiator when the vehicleis at slower speeds or stopped. This air flow removes heat from the coolant created by the engine using the radiator as a conductor. An engine cooling fan is temperature controlled to only run when needed.26 Jan 2017
if the unit had fuse or thermal protection it would not have popped the breaker. The compressor got zapped along with other components. Save a few bucks. Replace the unit.
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
check your airflow. grills open, filter clean etc. typically when a unit runs once and won't come back on without a reset it points to a safety switch that is kicking the unit out. By cycling power you are resetting the switch until the next trip. Many times related to lack of airflow.
The waste ink pad needs to be replaced and then the counter reset. Go to: www.inkjetprinterhelp.us and follow the online prompts for your model printer.
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
