You are absolutely thinking correctly....the humidifier should be running when ever the blower is running and the humidistat is not satisfied...in fact in some cases I have advised people even turn the fan switch on to run the blower longer to get more humidity in the air if needed....some furnaces do not have long enough run times to get enough water evaporated...
You have the idea of how it needs to go, so you should just go ahead and wire it up that way and you'll be glad you did!! You can get a relay for a few bucks and have a much better working system...
heatman101
